Sportster trike conversion rake question
Jun 16, 2019
2
3
Myrtle Beach
Converting a Sportster 48 into a trike using DNA axle. I've heard horror stories about being hard to turn with stock rake. The trike will be ridden by my petite wife, so I'm concerned. Well I don't mind doing a set of hhi trees, I wouldn't mind saving some money and going with some 3 degree bearing cups if that would be enough.
Bearing cups will move it in the wrong direction.
Rich, Welcome to Trike Talk from West Virginia.
The 3 degree cups won't do enough. Get at least a 5 degree triple tree to make steering easy for the Mrs's............:clapping:
3 degree cups will make it worse. Raking the trees will make it steer easier. Raking the frame will make it harder. Unless you install the cups backwards. Which is deraking the frame.
Rich first off welcome aboard. Second to get the straight information not just my opinion I suggest you take a couple of minutes and call RANDY (PAPA ZOOK) this forum owner. You can find his contact information by on the opening page go to the bottom and select CUT-N-SHOOT CUSTOMS ad. That is Randy's business and he sells rake kits at a GREAT price for members of this forum. He will give you the correct information for your setup so you can make the informed decision. Randy is a straight forward honest guy. Most members here will tell you rake it you will not regret that decision.
1983 sportster trike rake
I got a 1983sportster trike with servi-car axle and I purchasedan ajustable triple tree from ebay from italy that can be adjusted from -0to 10 degree rake, i currently have a 4 degree rake and it runs nice.
JeffHenk
JeffHenk
