trike lady
8750+ Posts
It looks like it has some damage.
In the circle, is that a broken tooth ???
The gap, is worn wide, and the fork is worn thin. It means that the fork cannot place and hold the slider gear that the fork rides in, in a correct position between the gears. Thus your chatter. Because of the wear, it also means that when the slider gear is pushed into a gear for engagement, that it's not pushed in far enough for a healthy gear change. The blueing on the fork and the slider, is from heat.
