Anyone else?
I had the coils backwards and the ground for the tps disappeared.
Flipped the coil wired and jumped the ground on rod. Then it lit right up.
Battery is dead and the alt belt is squealing.
[video]https://drive.google.com/file/d/0B291Vwl-NHGeV2J3S0pObWoyVDA/view?usp=drivesdk[/video]
All the mix and match electronics are trying to work.
It seems lean.
Gonna scale up the gas and try it again.
Just not enough time to stay on it.
It has now been run through several warm up cycles.
Things are loosening up and settling in.
Over the first start hots.
Scaled up the fuel tables and have it rich now.
The ford idle air valve is online now and working.
It idles on its own now.
The base timing is checked and was on 10 advanced with no advance command (no spark advance word from computer). That is the way ford intended it.
I reved it one time high enough to hit the cam.
It sounds beefy/chunky like a big block Chevy at idle and down low.
But when the cam comes in it suddenly changes and becomes a big motorcycle sounding engine.
Gonna be wild.
How about this way.
Well....
I guess not.
Was trying to get the video in the window.
All my old ways with.photobucket are gone.
I suppose I could make a new YouTube account and share from there.
Yep
Does video work this way?
[video]https://drive.google.com/file/d/0B291Vwl-NHGedVFWd3d1SElVNEE/view?usp=drivesdk[/video]
Yep
How about this way.
Well....
I guess not.
Nope
The sound overwhelms the cell phone pretty badly.
It sounds more like a big block Chevy until it get on the cam.
It has not been over 3500 yet.
Just barely enough to come into the cam.
Changes quick then and sounds more like a motorcycle.....a very big motorcycle.....but the scream sound of a honda.
This is a 7500 rpm engine.
like the idle sound, reminds me of a radial aircraft engine just started,before they smooth out. nice snap on the exhaust, idle rpm wandering around a little, I'm sure mixture changes will iron that out. I like it!
CedarRonin
CedarRonin
