reverse
Jan 22, 2018
26
8
australia
why is it that i cannot find a reverse to fit my trike with the first 5 sp transmission thanks
i did hear something about the early 5 sp had a tapered main shaft not splined which is the problem. im after more info if thats why .thanks
Just off the top of the head, the clutch release cover has a different bolt pattern on the pre-86 model 5 speeds.
You could update yours to the later model cover, push rod, ball & ramp and trap door.
Like above, there is not a large calling for the pre-86 models for reverse gear.
Use this link for seeing what will work.
http://partsfinder.onlinemicrofiche.com/ronnies/showmodel.asp?make=hdmc
thanks. what header pipe are you refering to,front or rear.there is a gap of one and half inches from the rear one to the oil tank.do you know if champion and mmd are the same internal set up.my hd mech has just fitted a mmd to a harley and recommended that one but i think he forgot mines the early 5 speed.mmd said there transmission cover and trapdoor are different to mine the first pic is mmd. the 2nd is champion.i appreciate your input
I looked at the install instructions and found that kit to be easier to install than the Champion 5-speed reverse gear.
I did notice 2 things:
The front header pipe will need to be moved if it comes too close to the hydraulic slave banjo fitting.
I am also not sure that the hydraulic slave cover offers enough clearance for the tension spring on the Zodiac.
Better ask the mechanic who will be doing the work.:Shrug:
https://beeldbank.prepublisher.com/pictures/PDF/ZDC/2/ZDCX0652.pdf
thank you mmd said the bolt on patten is different but it looks like my mech might have put on an adaptor plate to fit the hydro clutch but not sure.but the patten looks the same to me.my other concern is mine would have a tappered main shaft instead of a splined. do you think that would make any difference.i can not find the mmd instructions on the internet. thank you
thanks youve been a great help.that was my main concern.sorry for the questions but in your opinion do you think i will still be able to run my hydro clutch thank you
With the proper length pushrod, you should have no problems.
You might have to make your own pushrod.:Shrug:
trtro
trtro
