Question Normal Ideal Operating Oil Temperatures
Fearless
Gone But Not Forgotten
Gold Member
Dec 10, 2013
6,250
4,245
Clarion PA USA
Looking to build a fan assisted oil cooler system for old shiney (I know I can buy several different makes but I want to do it myself) and I cannot find what the realistic good oil temperatures are to be for the 103 TC motor. Any help would be greatly appreciated I'm looking a fans come on at 200 or 210 off at 180 to 190 degrees do these temps. sound in the ball park of optium temperature ranges? thanks Fred
Looking to build a fan assisted oil cooler system for old shiney (I know I can buy several different makes but I want to do it myself) and I cannot find what the realistic good oil temperatures are to be for the 103 TC motor. Any help would be greatly appreciated I'm looking a fans come on at 200 or 210 off at 180 to 190 degrees do these temps. sound in the ball part of optium temperature ranges? thanks Fred
I don't know if this will help you or not. I have the DK Customs Jagg Oil Cooler with filter relocation. My oil temps hover in the 200 - 210. I have never seen the temp exceed that range, no matter how, including triple digit heat.
Which Gauge?
Pat, just wondering what oil temp gauge you are using?
Thank you I think that is what I was looking for my old oil cooler is in sad shape 10 years old and never combed out or boiled clean. It's time to replace it OEM aftermarket one's are available but still smaller than I need to improve the oil cooling system. Thank you for the fast response. :good: Ride safe Fred
Going to have give me some time to look it up. Kevin @ DK Customs directed me to the one he is using, which I bought. I'll PM him and see if I can find it again.
Thanks for the reply. If it is the one Kevin uses I know what it is. I thought you might have installed a round gauge in the fairing or somewhere else on the bike.
Good luck with your cooler project Fred. I believe HD once stated 230 degrees was normal oil temp for Twin Cam engines;) I would prefer 200 degrees @ 85 degrees air temp;)
  • Like
Reactions: MDO
Nice to hear from you Jack I am thinking about using a fin installed thermostat coming on at 190-195 and off at 170-175 given the margin of error with that style I plan on lower settings. Thank you for your input I was hoping you would chime in. Thanks again I will keep everyone posted. It is my intention to make this cooler a switch out with no real changes,so it can be removed when wanted. Ride safe and put a few miles on for us here in Pennsylvania... I really appreciate you. Fred
Realistic, ideal oil temps for the Twin Cam on a Stage I Trike are in the 200-230 range, when measured at the oil tank. Of course, the oil is much hotter in the engine.
The reason for the 30 degree range is the oil will vary based on speed, load and ambient temps. I would not want to see over 230 when climbing a hill, at 70 mph, fully loaded on a 100* day.
Of course, on a shorter than 20 minute ride on a 50-60* day, level ground, it may not even reach 200*.
Unless you do a lot of short rides, I would not even bother with a thermostat. Why not give the engine and oil every chance possible to reduce temps by letting it flow immediately?
I regularly ride in the 30's and 40's and do not use a thermostat.
Thank you for your thoughts on this project the use of a thermostat was only for turning on and off the fan I may possibly use. The cooler came today it seems of quality construction now I need to fabricate the mount for it. Unlike the HD cooler the cooling chamber is the very bottom of the cooler which needs a little protection. A sandwich steel rubber washer will give me the clearance needed on a 1/8" plate the same thickness as HD mount. The new mount will be a bolt on addition of the OEM no chop and butchering here.
This evening I will be forming the mount it needs to be angled 10 to 15 degrees to level it and give little more ground clearance. I plan to use the hyd. press should be an simple operation. Once I have this ready to go I will install OEM cooler and go for a cold ride for me hopefully hot enough to get the oil temperature up to where it normally goes so I will have a baseline temperature. I have a long reach thermometer to use a good one at that. After inspecting the OEM cooler it is full of road grime and dirt 10 years old it needs at least washed out at best boiled and the fins straighten a little however it's going to be history soon.
While I was in the Man Cave
Well tonight I fairly well have the mount done. I took a good look at the OEM oil cooler Wow
So I then shaped the mount for the cooler
Figured out the spacing for the oil cooler close fit but it will work.
I still must manufacture lower mounts for the cooler spacers of sorts so air flows under the cooler and cools the regulator I think that is what it is.DSC01488.JPG
The unit looks very well made I'm taking my time when I finish install the support it will make a trip to the powdercoat shop an old friend of mine. So if anyone is wondering it is only 3/4" forward than the OEM and no lower. I don't believe it will cause issue there. Fred
pict
Fred i got them to load here ted
I still must manufacture lower mounts for the cooler spacers of sorts so air flows under the cooler and cools the regulator I think that is what it is.View attachment 82334
fred look above
fred look above
The cooler doesn't any larger than the oem let me see how the project I'm working on turns out. Thank you for posting it you should be able to move it when weather brakes in Florida and it gets hot. Thank you for your time and effort. ride safe and if you... do think of us Yankees in the cold. Fred
A little progress
DSC01510.JPGReally busy possibly changing employers again LOL. So to catch up on the oil cooler swap I fabricated the mount for the larger oil coolerDSC01486.JPG
Next was locating where the new one would have enough clearance between the lower mounts on the crash bars. I had to space out the left side 1/2" worked out perfectly.
The New oil cooler doesn't seem to positioned very much farther forward than the OEM.
View attachment 82750Really busy possibly changing employers again LOL. So to catch up on the oil cooler swap I fabricated the mount for the larger oil coolerView attachment 82746
View attachment 82749View attachment 82750
Looking forward to seeing how this works out...you should get a nice result in lower temps.
One thing I only now just thought about. Have you fully compressed the front forks (simulating hitting a big bump) to make sure there is clearance between your fender and the new oil cooler?
Fredmarkley5050#gmail.com
