Have shaky bike, it has a fork brace, and a new trike tire zero miles balanced of course, rear end measures straight. 15 pounds air in rear tires Ive run for 35years at 12lbs now 15lbs.
Tightened fork stem till it quit and backed off a notch. Originally in a stock frame, it was tweaked, i changed it out for a supposedly stock reman, its 2inch tall in the front legs and the rear seat is dropped.
Front end is a Kenny p, raked tree adjustable, with 10in over forks, when i had the Harley raked trees 6 over but needing 8 or i never had this prob.
Before i go back to a 10 over with Harley trees Im going to put a adjustable steering dampener on it. If that don't fix it, Im outta options.
Im into suggestions from the elect, that means you.
