A while back we talked a little about pinion angle.
I have been studying everything I can find.
I have come to the point sooner than I thought where I need to know what pinion angle to set and what drive shaft to order.
The pic below show how it is setup right now (but I do not actually have the shaft or joints)
I can change the angle of the diff down some if needed but I cant change the height of the transmission
I would like to shorten the distance down form 15" if possible but I want to keep the angle down under 20 degrees (the lower the better)
I talked to a tech at Tom Woods drive shafts, he suggested I use a double Cardan joint
He also suggested I keep the drive shaft angle under 20 degrees
Its been a very long time since I was in scool and I do not remember how to figure out these angles
I'm sure someone out there knows this better than me and can figure out the drive shaft angle given the info below
Can someone help me with the math?
I just realized from the pic it looks like the drive shaft is at 7 degrees but the pic is misleading. You have to go by the #s not the picture
![cv_angle.jpg cv_angle.jpg](https://triketalk.com/data/attachments/20/20183-5c03466254d07e9beaa181976668d9b5.jpg)
