fuses and breakers for reverse?
Jul 16, 2009
69
10
Donalsonville Georgia
Before pulling my reverse motor which is dead I was wondering if there is only the one main breaker under side cover? or is there other fuses which could also protect the reverse motor?
Thanks in advance
Thanks in advance
I only know of one......Under the side cover...Is the motor dead like in no sound at all or do you get a clicking sound....Every time mine wouldn't work it made some sounds..:Shrug:
Thanks in advance
What year TriGlide do you have?
There is a sticky in the beginning of this forum on troubleshooting the reverse circuit.
This is what Michael is pointing out to you
in neutral with motor running.
https://www.triketalk.com/forum/threads/49572-Tri-Glide-Reverse-System-Diagnostic-Tips
Hey Guys its a 2010 with 35000 on it, im the original owner. It threw the side breaker after running in reverse on a hill. ever since then its not made a sound. reset the side breaker and still not a peep. pulled it out yesterday and I am just now going to hook it up to my battery and see if its the motor or something in the harness/ all connections were tight. ill let ya now.
Hooked motor iup to good 12volt power source. Dead as a door nail. Going to send it off for rebuilding.
pull the brushes if you are comfortable doing that sort of stuff and clean them then try it again. I have repaired two by just doing some cleaning and making sure the brushes moved freely. Good luck
Just had the circuit breaker replaced under extended warranty. It has only tripped one time previously, my fault hit rear brake before releasing button. Reverse stopped working on recent trip , breaker wasn't tripped , 2 separate dealers I stopped at on the way didn't have breaker in stock , home dealer also had to order breaker not in stock
Also had reverse problem.
Was the same thing you were talking about. I pulled the motor out and took it to a local starter/ alternator rebuild shop. 2 days and $65 later I was back in business. I have a 2015 Triglide. They told me that I over heated it.
It is pretty easy to over heat this tiny motor
20-30 seconds backing up, let electric motor cool down;)
  • Like
Reactions: MDO
Jeff.........Welcome to Trike-Talk..........:wave4:.....
yantwohands
yantwohands
