advice
I re did DTC and have the same codes as before.
BCM
B2123
B2124
B2151
B2271
SPDO
B1210
Now my question is,, should I deleted the codes from then last time i did DTC ?
Yes, clear them
I bet your cruise control does not work if your brake lights are not working right
Clear the codes and rescan
You can check that here
1. bike off, run/stop to run
2. push set/resume to set and hold.
3 with cruise on/off switch to on, turn on bike
4. cruise indicator light should be green, release set switch, light should turn red.
5. push to resume and release, light should turn green then red
6. push throttle closed and release, light should turn green then red
7. push rear brake pedal and release, light should turn green then red
8. pull front brake lever, light should turn green then red
9. on models with a clutch/neutral starter lockout, pull clutch lever, light should turn green then red
whichever switch does not turn the light green, is your bad one.
if light will not turn green at all and you have followed ALL directions and tried multiple times, your set/resume switch is bad.
If light stays green even after releasing set switch, one of the dropout switches is stuck closed, usually the roll off throttle switch. unplug this and try again.
make sure brake light will not turn on without using brakes (wobbly brake lever, stuck rear brake light switch etc.)
Still no codes..
I check again for the cruise control,,now it will not work
You have a wiring problem some where, the cruise will not work if the brake lights do not work, pull the fuses 1 at a time and look carefully at them. Electrical problems can be a very hard thing to fix with out starting all over
Who did the install of your LED light set?
Is there any extra wires running under your seat to the rear of the trike?
Where exactly do you live in Jacksonville?
If you are close to me I can look at it for you
Assistance
The installer was done one of the businesses in Bike week in Daltona.
The only wire to the rear is for my amp for the speakers.
I live near the Berlin Road, 13342 cedar hammock way. close to the Rivercity Town center.
So to be clear, did you short out or connect the battery backward by accident?
All lights worked prior to new battery?
Did you get a warranty on the install of your LED lights?
Assistance
No,, it was not connected the batt backward. The batt is connected right.
Light was an issue before the new batt.
Yes I do have warranty for the LED.
I have to go out to dinner with my grand daughter, I will check back here when I get back
I am running out of ideas without having your trike here in front of me
Assistance
Good afternoon.
I will be on the road riding the trike. Need to get several patches on my jackets. If you have time today Here is my number 904-548-7532. If you have any other idea that i can work on the bike.
Good afternoon.
OK, check open Road Leathers on Beach Blvd, they do sewing @ a great price
If you have GPS, stop by my house 3566 Hampton Glen Place, 32257 , I can look at your light problem
I have test lights and volt meters 904-304-3545 Jack
His Freewheeler has a bad rear brake light switch, I found the code today. He has an extended warranty @ the same dealer I buy from here in Jax Fl. He will take it in and it should be good to go
We had a good visit today and plan on doing some riding soon
Glad to hear things turned out well...glad he didn't rob you...:laugh:
Drew73
Drew73
