Engine Date
Could not get the vid to work.
But that is looking 66 to 68 model.
That is a single port engine.
This was the growth spurt years.
1300, 1500 then 1600cc. They are all related.
Same case and crank..
Cylinders and valve size being the main difference.
ok so now were getting somewhere!!!:clapping:
I was reading somewhere that the cam plug on vw engine are rubber, what years was that type of plug used? If my leak turns out to be the plug and not the rear main, is there a way to replace the plug without splitting the case? if it has a steel plug could i replace it with a rubber one?
The vw cam plug has a raised v around it and fits in a notch.
This is the flywheel end.
This engine has had the galley plugs removed then threaded for pipe plugs (blue things)
This is an aftermarket rubber coated cam plug.
They are known to come out/fail easily. Nothing holds them in.
NEW-2pcs-FOR-VW-ENGINE-VALVE-COVER-CAM-PLUG-SEAL-078103113E.jpg_640x640_zps9na2ahnk.jpg
after seeing that raised section in the factory cam plug that pretty much tells me that to remove one if it is leaking will require splitting the case. i just really hope that its just the rear main that is leaking on mine!
Ok so I need opinions before I get started pulling the engine. which part failing would cause the most severe leak the rear main, the cam plug, or the oil galley plug? Keep in mind my leak is pouring oil out, after about 15 minutes of run time it dumped about a quart of oil on the catch pan. Also which is more common?
All that is fairly irrelevant because of how old and how "worked on" the old dub is.
I see more back yard mechanic mistakes than anything else.
Most oil?, galley plug, also is least likely.
If it has been worked on.....cam plug installed wrong. Or wrong flywheel for the crank. Or flywheel loose.
If it has not been worked on ..... main seal and hammered out bearing to case fit.
The least likely (but possible) is the engine is all fine and the seal decided to give up.
You will not know untill you take it apart.
It could be something totally un thought of.
Well I managed to get the engine out today, set it on the back porch. Once I got the clutch off I found that the gland nut( I think that's what its called) was tack welded to the fly wheel!!!:mad: Any reason that someone would weld it? Anyway, get a dremel after the welds and managed to grind them down enough to get a socket on it. after a few solid hits with a 1/2in impact the remaining welds broke and the nut came right off. pulled the flywheel off and found the rear main seal was still soft like it had been changed recently (I know it hasn't been changed in years). even though it was still soft about 1 1/2 inch of the rubber was torn away from the metal outer ring and the spring was just sitting in there but not inside the rubber like it should have been. so hopefully just replacing the seal and flywheel o'ring should fix my problem. sadly I cannot post pictures right now because it keeps giving me an error.
In the absence of an alignment tool, I once used a 13mm deep well socket to align the clutch plate. It worked perfectly. Slick hack or just dumb luck?:D
Well once I get my new seals, I'm going to try your trick! of course I will have to order the parts, but the clutch seems to be ok for now so im not going to replace it at this point so I wont have the alignment tool lol:D
Ahhhhh. Another hack job.
Is it a 180mm clutch or 200?
The only reason to weld the nut is because it keeps coming loose.
The main reason it comes loose is wallowed out dowel pin holes.
Check the pin fit in crank and flywheel.
If the pins wiggle or spin in the holes you have big problems.
Wiggle and spin on the main bearing while you are there.
And.... flywheel o ring.......sounds like you have the correct flywheel for a 67 and up.
20170603_142139.jpg Looks like im going to have to get a new clutch fork bushing too:(
As you can see the main seal was the cause of the major oil leak! Of course nobody around here carries the parts I need so I will have order online.
The dowl pins all seem tight in the crank and the flywheel, im wondering if the last time it was off the person doing it didn't have the right tools to get the gland nut tight enough so the tack welded it to keep it from backing off. actually that what im hoping for. im not sure if its 180 or 200 clutch, I do know it is the old 3 finger pressure plate, I will check later to see if its the 6 spring or 9 spring, and I will measure it to see if it is 180mm or 200mm.
Ok got a few more pictures of the pressure plate and clutch assembly.
If I did the conversion right, it comes out to 177mm so I guess that means its a 180mm clutch disk. with a 6 spring pressure plate. also you can see the gland nut, and what I had to do to get it off lol when I order my main seal I guess I will be ordering a new gland nut and roller bearing.
Hmmmmm.
interesting
Looking like a 66 model 1300.
How many teeth on the flywheel?
Washer is missing on gland nut.
stock washer does not fully cover dowels. Around half way maybe.
Maybe with the missing washer someone thought they were keeping the pins in the holes.
That is the lightest grip of all the clutches right there.
Hmmmmm.
interesting
No clue on the number of teeth on the flywheel, didn't think to count them lol.
Yes the washer is missing, all the tack welds are covering the dowel holes.
with it being on a trike with a really light front end, would it be wise to stay with the light grip pressure plate?
Number of teeth will help identify it further.
I would increase the clutch.
the 180 should not be a problem on a non hot rod trike.
If you can find it a nine spring, or a luk diaphram.
No need for a hot rod "stage" clutch untill you add more power.
LOL there will be NO power added!! I was talking to a guy that worked on it years ago before it got shoved in storage and he was telling me that you can't use first gear unless you want to drag the crash bar off the back! so with that being said, I may just leave the clutch the way it is for now plus my wife will be the primary driver of it and doesn't know how to drive a manual transmission so she will be learning. No sense in spending money on a clutch just to burn it up, I would rather wait a little while then put a new clutch in it after the learning process is over.
Roadrunner1
Roadrunner1
