njtrike
50+ Posts
Has anyone figured out what to expect for top end speed. I have done the tts2 tuner, rush true duals, rush mufflers, and big sucker air intake. Thanks
The speed limit without a problem. Not nearly as fast as my Ducati used to be, but it is a Harley.
You and I both know out here, the "speed limit" will get you run over.
Same in Houston. If you can't run 80 - 90 on the slab you may become a hood ornament on an 18 wheeler. And I see 95 occasionally. But watch the brake lights ahead of you as they top the next overpass. :laugh: Not long after the CSC conversion I ran 95 on a stock 2012 Electra Glide and that wasn't maxed out. Haven't tried for max since I had the Stage 1 done. Maybe some quite Sunday morning.You and I both know out here, the "speed limit" will get you run over.
I’m getting to this post very late but my 1999 FHLTCU-I with a Hannigan trike kit will only do 75 MPH (on GPS) with wide open throttle! My bike has the 88 Cu In. engine.
Is this all I should be expecting?
