I thought I'd post some pictures of my raising of my Wife's Freewheeler using Rhino ramps.
I was able to ride up on the ramps with no issues.
These ramps certainly allow for much appreciated access to under the bike.
View attachment 94429View attachment 94430View attachment 94431
If you notice in his pics he has his ramps on a rubber pad of some kind. That will help keep them from sliding, if you have an epoxy floor like I do I suggest something under them to keep the tires from pushing the ramps.
It looks like that set up works great! If anyone is using ramps that slip, you can attach a piece of carpet under the ramp extending ahead of the ramp about 10” or so. That will make it stay put.
I enjoy my J&S Trike lift for most things (changing tires, inspecting the underside and cleaning). But is a pain in the a$$ getting around the lift arms for oil changes. So I use the lift and lower it down on 3 car ramps. Works every time.
It was a toss up between the $800 JS Jacks trike lift and the $40 Rhino ramps. :xzqxz:
IMO the JS Jacks is the best made jack/lift out there but with all the bottle jack failures and customer service complaints I’ve seen I’m not sure they are worth the price they once were.
With my $100 standard floor jack with $40 beam bar along with 3 inexpensive jack stands I can get the trike fully off the ground when needed but for simple maintenance like an oil change all that’s needed is just a little more room which the ramps adequately provide.
