Very nice Jack! I like the color! Enjoy!
Very nice Jack. How does that 114 feel? Also, will your Power vision tuner work with the 114?
Now you gonna have start the adding of performs parts all over again..:xzqxz:...
This followed me home today
Congrats, she’s a BEAUTIFUL gal...........BTW how many miles did you put on the other one?
:Coffee:
I Ain't seen one that color yet , Look's Good . Ride the Piss Out of it and enjoy ! Be safe
Thanks Dan, I am heading out in the morning to do the break in miles so I can get the oil change in @ around 500 miles then again @ the 1000 mile mark. I do not take it in for any services except recalls , but I keep very good records and have yet to be called out on it
On my new motor , I dumped the oil at 50 miles , It did not look good , I had that reuseable filter on took that off put on the new m8 filter, did it again at 250 cut the filter open all looked really good , Did a leak down test 4 % front 2% rear . The motor is so quiet no valve train noise , no primary noise . I better shut the f up before it BLOWS UP AGAIN ! Enjoy your new Trike
I hope you have good luck with your new engine after the crap you went thru.
I am big on getting the first oil out of the engines way before the called for 1k
I'm curious if the 114 is like my 107 was, the 1st. 1,000 miles, it burned almost a quart of oil, then stopped.
This 114 has a lot of power. It did not take much to get back to using a cable pull clutch.
It feels good, and releases sooner than the hydraulic clutch did.
It also feels to me this 114 runs a bit cooler than my 17 107
Jack what do you think is a safe engine temp ? I went saturday to N Y 80 degrees, 80 mph, for about 80 miles, the highest engine temp was 272 going up a long hill about 3 miles its the highest elevation on the mass pike ? oil temp said 215 THANKS
