I also put in a k&n. Because i have an extended warranty and really don't trust moco, i bought a backing plate and breather hose, then notched the backing plate at the breathers at six o'clock so the breather hose set in tight after i disconnected it at the t. Drilled a hole in the backing plate at five o'clock, and connected ebs. Ran hose to front of trike, away from heat sources and mounted filter on right frame rail about 1 foot in front of oil pan. If i have to get warranty work done i can put the original parts back on.
Going to order dk custom complete intake kit, so am I reading right that an ebs feature without hoses is included and if so where does the hot residue go.
There's a good thread in the Tri Glide Section about EBS, Breather Bolts and Stage 1 Air Cleaners. Initially I wanted the Breather Bolts, but changed to EBS w/Catch Can after reading this thread. Note Comments in Post #23 on Breather Bolts.
View attachment 73263install complete, kind of small but look okay. I haven't had time to test ride it yet. EBS, VIED, V&H straight shots leaves me curious how it's going to run.
