I did get a response from Innovative Balancing. Basically, they said that if I just loosened the valve until air leaked, there shouldn't be an issue. I ordered the filtered valve stems and a new valve removal tool ... the one I got from Dad broke when I was putting back into the stems, had to snug them up with just a valve cap that had a removal tool built in.
I will wait to get the valves, then slowly bleed the air, install the filtered valves, then do the Nitrogen. Apparently, you can bleed the air faster with the filtered valves.
Wouldn't of been a big deal if I didn't want to add Nitrogen.
When I bought my Dyna Beads, the stems were included. 3-4 yrs ago. Must be like HD cutting items off to save a nickle. I bought them 2 separate times. Once for the trike , liked them, so bought them for the truck also. Both times the valve stems were included.
