advice
Mar 22, 2022
52
30
JACKSONVILLE
I have a Freewheeler Trike HD. I install a new batt and now my rear left light dont work, plus when i hit the break the stop light will not work. Plus I have LED lights and they stay on in red color, it will not change color. What can it be the problem
So you do live in Jax Fl.. Good
The LED I have on the bike is Shock&Awe2.0
Yes I do, Mandarin off SanJose and 295
See my post #2, scan your trike and post what you find
If you have trouble with the scan you can stop by my house and I will show you how to do it
3566 Hampton Glen Place, Jax Fl 32257
it sounds to me your system is in sleep mode from the disconnect and re connect of your new battery, see below on the instruction page and try a reset
Sleep mode:-To enter sleep mode, press and hold the button for approximately 3-5 seconds. The lights will flash indicating sleep mode.-Once in sleep mode, the motorcycle cannot not be found through Bluetooth; this minimizes any possible battery drain. The lightscannot be controlled through the APP in sleep mode.-A simple short press of the button will take the system out of sleep mode and be discoverable again.Factory reset: -Press and hold button for 10+ seconds, the lights will flash. -This forgets all Bluetooth settings, and system would need to be rediscovered through the APP.
ok,, i did it. what I read is as follow:
BCM: 62123 / 62124 / 62151 / 62271 Pn: 69994-128
SPDO: 61210 Pn 70900379
What year is your Freewheeler, are you sure about those codes, the 6 are B, the part number is the BCM that is showing the codes
Follow that same link and clear the codes, start your trike after you reset your light kit, see post #8
The last code is a low BCM volt code, will your trike start?
Sorry to ask,, but you mention to press down the button. My question is,, what button :(
The trigger switch on the top side of the Left Hand side switch pak, # 11
yantwohands
yantwohands
